Well, as stated in previous threads, I'm struggling with some intermittent issues on both my 84 454's with only 478 hours on them. As per previous threads, both engines were pulled out and "checked" prior to me buying boat. Shafts, struts, cutlasses and stuffing boxes are new and/serviced. Distributors look almost new (old mallories points and cond), fuel system(s) new including a "rebuilt" on the port side.
Two major (not life changing but annyoing) issues.
1. Both motors have had an issue where after cruising along just fine at 3100 RPMs, I have to come off plane for one reason or another. Then, as I go to power back up, one of the two (and it does alternate lately) won't climb above 2600 rpms.....in most cases, after a few minutes of me cursing and messing about, all of a sudden, it will climb up to proper RPM and run just fine all day. I can smell the exhaust getting very rich when it happens on either engine.
2. On one motor, the one with the rebuilt carb, after cruising for a bit (assuming the above didn't happen), and I go to back in to a slip or idle around a bit in a cove, the idle falls out and it stalls. It doesn't happen every time (only when the wind is whipping and I'm squeezing into a slip much too small for my boat with expensive boats on either side ;-)). It always starts right back up and then just goes away after a while. This is a real oddity as it only happens on the way to go somewhere and never when I'm pulling into my slip (go figure).
My thoughts are this.....
As I'm only going by what the broker and last owner told me, both engines were completely checked out when pulled. I can state for a fact that all fuel lines, fuel tanks, RACOR (just replaced) are all new. the port side carb (that stalls) was rebuilt and looks brand new. It seems like there were a lot of extra distributor parts including coils (which are new on both motors btw). Kind of makes me suspect they were chasing this down.
I'm thinking of replacing the distributors with electronic just to completely isolate for that being an issue (and let's face it, it's a good preventive maintenance that yields some serious efficiencies). I'm nervous doing this as I'm no ignition expert but have done this in the past.
I've read almost every thread (chris's from 2013 was captivating) and think this is the best start to troubleshooting this. Given his issues with a rebuild, I'm thinking maybe sending out for another one and replacing so I know it's new.
What are the general thoughts on brand/type of distributor? I was thinking the delco EST kit. I'm assuming I need to buy an RH and LH? And....check me here, I determine RH by looking from front of engine correct?
Input appreciated, I'm not going to rush into this as basically, the boat is running great 90% of the time so I'm in to listening to any and all input........
RESOLVED - I had a mechanic actually go down to check out engine. I relayed that I felt it was the secondaries not opening up correctly as the port side kept getting stuck at 2900. He called me later and basically stated that I had low compression in both motors across the board (90's). Even with that, I wasn't convinced that all of a sudden my boat didn't work right. Second issue I had with diagnosis was that he did not do a leak down and was already writing the engines off. I had already ordered new Voyager EST's so figured I'd wait and see if that had any affect. I changed out the port side with no affect. The engine would not get above 2900 to 2950.
Very depressed and defeated, I limped back to my slip. I made a call to Yacht Services (Todd Brice) and asked if his team could give me a second opinion. I dropped off the boat yesterday thinking best case, new heads for both engines and a ton of money, or....worst case, new blocks for 12 tons of money....that I didn't have on a boat where the motors were pulled recently and supposedly checked............
So....not in my best fantasy did I think I'd get a call later that day (figured it would be at least a week) that all was fixed and it's good to go.......compression was at 115 give or take a couple of percent and the issue was carb and timing. I had only asked him to look at the port side but he checked both engines and got everything back in line. The carb issue.....as I had stated to first mechanic.....the secondaries were not opening.....
The boat is over propped of which I'm going to rectify over the winter but all in, he got it running better than I ever have seen with these engines. Yes, the WOT is only 3800 but that's due to the oversized props (which I didn't know about when I splashed).
Moral of this long drawn out story......always get a second opinion and always go to the person(s) you trust. I have been with Yacht Services in the past with two boats (kept both there for some time) and now he's got a customer for life. Going to haul there and keep the boat there from now on.
Talk about relief.......
