Lower helm
birdog
I'm looking at a 37 sedan with a bridge helm only. My last cruiser also had a lower helm that was nice to use when I was by myself around the docks, trying to drive the boat and also handle lines. I've never heard of it, but does anyone make a compact steering/throttle/clutch control system that could be installed to solve my problem? Even if there were, I suspect it would be very expensive. Maybe I should just keep looking for one with both helms.
i think the topic was beaten to a slow and painful death very recently, check a couple of pages up...
to answer your specific question, yes you can add a set of engine control on the aft deck or cockpit which makes it easier to single hand the boat. If you have manual controls, it's jsut a matter of adding a set and run the cables to the ER. pretty easy and inexpensive. Same with electronics controls, simple (jsut a wiring harness) but probalby a little more $.
well worth it.
Are you referring to a lower station in the salon if it has a forward window, or is this for the aft cockpit? For controls Teleflex, Vetus and others have several options for electronic or hydraulicly( these are great for multi-stations) -operated engine control systems, and for steering if space is limited you could use a smaller wheel on a hydraulic helm ( obviously a bit more efforrt than larger) or perhaps just tie in a Simrad jog control ( follow-up or non-follow-up) to the A/P. This kind of jog control isn't likely to have as precise a feeling as a wheel helm but some still find it handy for temp use. I'm not aware of an all-in-one steer/control system.
I didn't know this topic was hashed over before. I was thinking of something that would mount in the salon, rather than the cockpit. I thought maybe someone offered a complete system that could be retro fitted for a variety of applications or boats.
if you just want engine controls to maneuver, it's easy to add as mentioend but ideally should be aft to be really useful. Not sure why you'd also want steering there.
if you want to actually drive the boat from downstairs then you'd also need gauges, horn switch, etc...
if the boat has hynautic steering, it's not that hard to add steering, it's jsut a helm pump/wheel and running lines to the existing circuit.
complete system cant' exist, too many variations.
but again, if you just want controls to dock the boat, then just put a set of engine control in the cockpit. not much point in having an inside helm if you dont' have side doors.
Just because many of us use the upper station ("room with a view") most of the time by far doesn't mean the lower main or cockpit station isn't a very valued feature of the boat when needed or desired. I wouldn't be without the lower main and also use a long-cable wired remote Simrad A/P control for the cockpit for trolling and frankly would love to have a full 3rd station back there but the boat isn't big enough to warrant it.
