Take a look on the side of your seacock, is there a small pipe plug? If so that is for a grease cup. You can either buy brass grease cups for each seacock or get one and move it from seacock to seacock as you lube them. You could also adapt a zerk fitting to use to do the samething.
I guess I need to clarify. What you are showing is a ball valve. Those, for the most part, come with Teflon seats so they should not need lubricating.
What I was referring to is the classic style of seacock with the large valve body. Those do and can be lubed via the plug. Groco sold/sells the grease cups. But you can easily find them on the Net as well.
I have put them on any number of seacocks over the years and the work very well.
Since we don't know which style he has, either of us could be right, or not.
