macerator pump location,99 glastron gs249
bannditt
1999 glastron gs 249,does anybody know where the macerator pump might be located?hey charlie thanks for the tip on the tach.worked great
Not familiar with your boat, but they are usually located within inches of your holding tank. open any and all hatches that access your holding tank and trace all hoses. You will find it assuming you have one and you might not, even if you have a switch on your 12v panel for it.
What CWMS said. Turn the switch on and listen for it with the hatches up. Agree, might not have one.
A little late but are you sure it has a macerator pump? - I don't have one on my '02 GS249 but the shower sump pump is under the step from the cockpit into the cabin. The step is just a hinged lid to a compartment that has the shower sump pump in it.
