I'm considering purchasing a new to me boat with a pair of RWC 5.7merc with alpha one outdrives. The boat has one new engine (port) with about 70 hours on it and both engines had new risers and manifolds installed in 2005 with very little fresh/brackish water use. We sea trialed the boat yesterday and the surveyer mentioned to me that both engines had manifold and riser temps of about 180-190 degrees at cruising speed (3200 rpm) as measured with an IR gun. The engines themselves ran rock steady at 145 degrees the entire time including several minutes at WOT (4200 rpm). The surveyer suggested that all the manifolds and risers should be replaced due to high temps. I didn't think that 190 sounded excessive for crusing temps. I cannot seem to find a spec mentioned anywhere as to the correct operating temp of manifolds/risers. It would seem to me that they would run hotter than the block temp due to the hot exhaust being dumped into them. The owner is not of the opinion that the risers are too hot and doesn't believe he should replace them. This puts me in an ackward spot, I don't want to kill a good deal based on this info. What do all of you think about these numbers? We can get the boat at substantially below book price and we like the layout and general condition of the boa. I'm thinking about doing the deal and pulling the risers and cleaning/inspecting them. If necessary I can replace them myself for only the cost of parts and a day of my labor.
Opinions please
Opinions please
