Matching Paint
Crossroads
I removed some deck hardware along with some deck railing and patched the holes. I need to paint the repaired area. The boat has been painted a white color by a previous owner but it is not pure white. I want to buy a quart of white deck paint and then try to match the existing paint by adding something to make it a little off white and more eggshell in color. Any idea what I can add to the paint.
How about using the coloring agents like found in gel coat repair kits?
I'm not a professional, but I've always just bought very small containers of other colors and mixed in. Just a tinge of brown/yellow maybe.
Start with yellow, tiny amounts are needed.
There are usually 2 tones of yellow, go with the darker one first and experiment.
if you can remove a small piece of the existing paint, take it to the paint shop they will make up a custom color to match the piece. its what they do and they will make as many of em as you need. the key is to get the sample made up dried and then take them both out into the sunlight to compare them.
Your best case scenario would be to follow Vic's suggestion, if possible.
An alternative suggestion would be to get a color chip pack from a paint store and use that to closely match your color. The better stores usually have these for the pro painters.
From a color specialist; me. A couple things to consider when matching paints. If you use tinting pigments; you must be positive they are compatable with your specific paint. Another issue, tho it won't be that bad with an off white is: If the pigments are different than those used in the original formula; the color will look diferent under different light sources. In dark, rich colors; I'm talking night & day difference.
