The boat has an undiagnosed stall at idle about one slowdown in hundreds. I bought an IAC hoping it might clear the problem. Still a stall once in awhile, very rarely. MerC master mechanic with scanner could not find anything.
The IAC I put back is the one I replaced and did not change anything. I think it has about 1000 LESS hours on it than the one I put back. I was very fortunate to guess what tools I needed and packed them up along with some throttle body spray cleaner. One connector and two small Torx screws. Removed one, sprayed cleaner, installed new and ran bilge blower till exhaust didn't smell like cleaner. Started right up, idled right, ran simply GREAT all day. Very fortunately. We were 25 miles from home and had a mission to run that went about 20 miles, then all 25 back. Faultlessly.
Michael, I'd like to test TPS sometime, for now thankful to be running and likely won't mess with it unless symptoms return.
Sandy, There is not a filter. I think it relies on air through one part of the throttle body diverted to another part. I've heard of that learning and seen it on a Ford but didn't happen this time on the GM Rochester TBI system. The TBI seems to be automotive but with a MerC version of the ECM. There is no MAF or MAP sensor.
Harlan, I think you're talking about a SmartCraft MerC engine and ours is not. You should have seen River City Marina yesterday after the air show! Tide running out hard, river all chopped up with part of the 1000 spectator boats running through. Needed Sea Legs to walk the Fuel Dock!
Charlie, Idle speed SOG when things are right is around 2.5KT. Yesterday at 1500RPM neutral idle the "idle" RPM was about 1200 and SOG 5.6KT. 2200 would be close to 9KT, but I couldn't check it yesterday in that running current.
I've had a long three days. 135 miles on the three days of air shows. Thanks for all your suggestions. Next problem post before long... Water dripping out of TOP of Lower Shift Cable!
