merc cooling
misindale3
I have a 76 302 (ford) merc in a cobalt boat. I think it calls for a 140 degree thermostat. I couldnt find one locally. I would of had to order it. the closest I could get was a 160. I put that in and put the ear muffs on it and started it up and it started to over heat. So I just pulled the t-stat out. my question is- is it ok to run without a t-stat? thanks for any help in advance.
The 160 thermostat although incorrect shouldn't cause an overheating condition. You need to check further,raw water pump is suspect,if you had the muffs tight enough for it to draw water properly. You may want to stick the boat in the water and see if it cools. If you haven't changed the raw water pump in more than a couple years, put in a new one. The 160 thermostat should open and hold the temp at 160 or close. You are better off with a 140 as this is the right temp to run that engine at. The 160 may cause other symptoms like hard starting when warm or running on when you shut off the key. It's always best to stick with the original spec'd thermostat.
No.
You risk warping the heads along with all kinds of other unpleasant things.
The correct temperature allows various sensors to do their job like spark timing and fuel mixture, etc.
No.
Guys, correct me if I'm wrong but the warping of heads is due to overheating. Running without a t-stat will most likely have the engines running cooler than it's supposed to run, not hotter. Am I wrong?
thats what I thought. also, my engine is a 1975 model.....no sensors or anything, just a good old fashioned engine.
That would be correct. However.....it is never advisable to run engines with no thermostat. They"re there for a reason. If they were meant and designed to run without them then they wouldn"t be there in the first place. I hardly think that running a 160 degree T-Stat in there will harm anything. I"m not saying that is positively correct but if it were me I wouldn"t think twice about it. I"m pretty familiar with that engine and 160 degrees is definitely not to hot for it.
What"s bothering me here is that you said you put the 160 in and it overheated......THAT would indicate another problem.
Why did you decide to replace the Thermostat to begin with?
If the cooling system is operating properly then then temp should hold at whatever degree thermostat you put in there. Put in a 150.....it should fluctuate around 150.......put in a 180.it should fluctuate around 180 etc., Putting in a higher temp. thermostat than what you think should be there won"t make it necessarily overheat but might make it run warmer than the specs call for. I highly doubt however that 20 degrees hotter in that engine will do any damage.
I totally agree that you should run an engine with the designed t-stat. I'm just saying, if for whatever reason, you had to run an engine without one, you are not in danger of major problems such as warped heads.
I just bought the boat and the t-stat wasnt in it. took it out for winter I guess. Also, I put a new impellar in it and I know its working because when I ran it I opened a petcock and water come shootin out. now, when I had it runnin with the muffs on, the temp gauge went to the redline and thats when I shut it down. the t-stat might well have opened up from there, but I got worried and shut her down. maybe I wasnt getting proper water flow with muffs, or maybe with a higher t-stat my gauge will be off. I dunno. I'm putting the 160 back in and taking it to the lake and trying it out.
if it wasn't right on the muffs, it won't be right at the lake.
Running on the muffs will always make it run cooler than it will on the lake. The added pressure of the water supply will force more water through. Put the muffs back on it and pull the water hose at the Thermostat end (water feed line from outdrive) and check for water flow there. You might have a blockage there somewhere and just happened to open a petcock that was in front of the obstruction. (if there is one)
Check the water flow there and if that"s okay then (before the engine heats up) leave it idling and put both hands on the manifolds. See if one heats up quicker than the other. Even with the boat at full operating temp. you should be able to put your hands on the manifold without burning. They:ll be HOT.....but not so hot you can"t touch them.
If one side is getting hotter quicker than the other....that"d be a good start for a place to check the flow at next.
Try the lake just in case the muffs weren't sealing properly. I used to run my 1974 140 mercruiser with a 160 thermostat because I used it for trolling on Lake Michigan. As long as I was doing the trolling and fishing in cold water it worked great. Problem came when I took the same boat to smaller inland lakes with warm water and used the boat to water ski. This is when I would have dieseling problems. Once I changed back to the 140 thermostat the dieseling disappeared. Lesson learned for me.
If you're still overheating at idle while in the water you have a circulation problem somewhere. Was the boat ever in saltwater? If so could be a number of things including a major breakdown of the internal water jacket. Try removing a plug from the exhaust manifold while it's idling. If your getting decent pressure there try removing a plug from the block. If the water is just running out (no pressure) maybe your engine water pump (the one in front of the motor) is shot,otherwise look for blockage in the water ports. You just need to break it down and check each piece of the puzzle. Tom
See Greg"s Post above.
Don"t waste your time dragging it to the Lake.
i'm beginning to think its the cheap muffs I bought at wal mart. I put the 160 t stat in and hooked up the garden hose and let it run. I pulled hoses, pet cocks and anything that had to do with water and I was getting water out. my temp gauge would show overheat then would drop then would overheat and drop.....kept doing it. I looked back at the muffs and there was alot of water coming out from around the muffs like if they werent sealing. I even went as far as taking the lower unit apart to make sure I put the impellar in correctly. I will just take it to the lake and see what happens.
I've never seen anyone running muffs that water wasn't shooting out from all around. Just the nature of the beast and the hose supplying more water than the motor needs.
Very important that you check the water flow to the manifolds. If it"s strong there the you may have a bad manifold or at least some sort of restriction somewhere there. If the gauge is going up and down then the thermostat is working ok.....Maybe the gauge is off? Maybe the temp sending unit is bad? Maybe it"s really not overheating at all. At what temperature does it stop rising and start coming back down? Try running it and actually reaching down and touching the manifolds..they:ll be hot but not enough to burn you. (assuming it"s NOT overheating that is)
just wanted to let ya'll know I put the boat in the water and it never ran hot. I think the muffs werent letting me get enough water in it. I did however find that I've got a cracked manifold.....I've posted a new topic in the engines forum to deal with it. thank you all for your help
