1997MontyMontura
New member
- Aug 20, 2025
- 37497
- 1
I have a 1997 MCM 4.3 LX Gen +, starts fine after it has been used within the last day or so. Runs awesom on accelaration, high RPMs, but recently stutters and rought at idle. I have had this intermittently over the 10 years that I have owned it. My engine is carburetored. I have the carburetor rebuilt twice, both times it worked fine for a season, then started doing the same thing. I have it rebuilt a third time and the tech told me the other two times the carburetor was rebuilt they never took out the idle mixture screws / jets because he had a hard time removing them. After this third rebuild it has been fine for the past few years. It just started back doing this again with the rough idle. If it doesn't start up within the first few rotations, I have to give it throttle while turning it over and it will race and smoke for a bit then calm down once warmed up. I have added Sea Foam Pro (marine version) to my last half tank, but doesn't seem to be helping. I may try what was suggested above to let it sit after I see the smoke. One odd thing it has done, again intermittently, it can cut out for a brief half second while tooling along.. very intermittent... but not sure if these two issues are connected. I will update this if I come up with a fix. I am on vacation and the marina tech is supposed to come by to take a look. I hate to have the carburetor rebuilt again, but seems some folks rebuild their carburetors every winter because of the ethanol in the gas. Oh, fuel / water separator and screen just before the gas line goes into the two barrel carburetor have been replaced as well as the spark plugs. I will add a pic of the spark plugs I took out if anyone has any comment on those.
