- Nov 21, 2002
- 10785
- 215
Throw this out and see if I am over looking anything........I finished out a houseboat which I bought last year at auction when a houseboat company went out of business. I moved it to another houseboat manufacturer to install fuel tanks, generator engines, outdrives, etc etc
It'S 16'X86, with 4.3L engines installed with Bravo II outdrives. It was splashed in mid summer this year.
Upon splash the port engine would over rev at wot, the starboard ran at normal wot rpms.
I had right and left hand props installed and the Mercury left hand was on back order when splashed with an after market prop in its place...thinking it might be the prop a Mercury left hand prop was rebuilt and installed, it kept it from over rev but still out of range.
The Mercury left hand came in and was installed which caused the over rev problem again.....NOW not really having a baseline to go on, I had two good props off my old boat which I knew turned the same and had them put on. Same result, starboard in tolerance and port over rev.
I am thinking that Mercury geared the outdrive different than what was ordered and what the paper work calls for and what the outdrive says
According to Mercury via the houseboat company which finished it out, that could be the case as he says all gears come down the same line and the wrong one could have been installed....wtf kinda of quality control is that?
We were told to pull the boat, take off the outdrive and turn the shaft and count the prop turns and if it was wrong they would send a new outdrive. When told you just don't run this up on a trailer and the shipping on the outdrive would be cheaper than a second pull they are sending a new outdrive.....
We plan on putting the boat on the trailer backwards and just up the ramp enough to change out the drive and hopefully that will be the cure....anything else you can think of??
