Originally posted by Chief Alen
even raw water cooled mani's last the life of the motor, mine actually was transfered from the first motor that was 20 years used in saltwater.
And the motor would still be in my boat cause it was the head that went, and i pulled a corner bolt hole up installing the head.
Need risers buy risers, i would even bet the mani's are still good.
The life of the motor? In salt water? You're a better man then I am. Those things must be made out of some super alloy.
Around here you get about 3 to 5 years out of a set of manifolds and risers that have salt water pumped through them. The OP explained that he was concerned about spilling coolant and raw water, so it sounds like he has a half of a fresh water cooling system.
If you're a gambler, you can take your chances beyond that if you feel lucky. Too risky for me though.
I have a friend who owns an auto repair shop. He is also in to boats and always has a couple of them around the shop. He's been playing around with buying and selling boats for about 30 years.
He usually gets them like this:
A customer stops in and asks "are you in to boats? I see you have a couple here.
reply: Sure!
Customer: I have this boat sitting in my driveway with a bad motor. Will you take it off my hands, or make me an offer for it?
reply: Maybe! I have to take a look at it first.
Every boat he bought in the last 30 years that needed a motor he got because the previous owner didn't change the manifolds or risers, or tried to get away with changing just the risers.
The funny part is that once he opens up the hydrolocked motor to take a look inside, they aren't in as bad shape as you might think.
The motor is shot because of the damage caused by the water getting in to the cylinder through the exhaust port in the head(s), but other than damage related to that ,the bearings and everything else are usually in surprisingly good shape.
He buys them, changes the motor, then usually uses them until someone buys the boat. Then he moves on to the next one.
Last years score was a 24' Searay. Bought fixed, used, and sold. This year he is finishing up a Four Winns, and he has another one already lined up for when this one sells.
He's the only guy I know who always makes money on his boats.
Bottom line: Keep an eye on manifolds and risers on a boat used in salt water. They are easy enough to change, and a whole lot cheaper than a new motor.
