Mercruisers won't start
bushwood
Twin 225 (Ford 302)w/Holley carbs both decided not to start. Engines crank over fine. Stbd carb has now gone dry. I've pulled dist caps and appear dry-electronic ignition. I've poured some gas down both carbs with negative result. New coils 4/05.
Never had this problem before, especially with both engines refusing. The only new element is I replaced hoses from both fuel pumps (mechanical) to carbs. Stbd fuel pump new in 6/04.
