Money saving boating tips
Well-known member
Let's all post techniques we use to save a little on boating expenses. Here is my first tip:
To seal the ends of cut lines: Tape the line tightly with 1" tape then cut the line in the middle of the tape using a sharp blade leaving ВЅ" tape ring on each cut end. Dip the cut ends into plastic pipe glue and let dry. You can use that liquid whipping stuff from the boat store if you want to spend more but the pipe stuff works well for me and I always recognize which lines are mine because of the blue ends.
Siphon gas out of my slip neighbors fuel tank. This really does not work though because I suspect that he does the same thing to me.
Seriously though.
My marina has several Yamaha owners. We buy 2-stroke oil in bulk and divide it amongst us.
Buy Smirnoff Vodka in the largest bottles you can find. Refill your Grey Goose bottle with Smirnoff and serve it to your guests who believe they can tell the difference after mixing it with redbull, tonic, juice, etc. (they can't) When serving martinis to discriminating drinkers, you might have to pull out the good stuff, but otherwise Smirnoff goes down smoothly and if you party/entertain like we do, you'll save enough cash to buy a tank of fuel.
I'm sure everyone knows what BOAT stands for.
"Bring on another thousand"
Sometimes I just sit in my boat...on its trailer, in the driveway. For added ambience I listen to Pachebel's Canon with a breaking surf background and make a "vrooooom, vrooooom" sound from time to time which simulates a high idle cruise in a no wake zone. I farted once and had to stop to investigate the popping noise. Wasn't serious, thank goodness.
slow WAY down. Running barely on plane, or worse, "on plow" typically costs MORE money.
...or were you talking about Mike's flatulent wake? :)
Wait until the tide is going in the direction you wish to travel, idle out from the marina to the channel, turn off your engine(s) and let the current take you to your destination.
We put in Bennett trim tabs and can be on plane at lower speeds than normal. With tabs we also can trim the outdrive to parallel the water and let the tabs keep the bow down.
Adding gas station instead of higher priced marina gas to the boat.
I was siphoning ITK's gas, but somehow the gas gauge needle never seems to be on full the next morning.
SLW,
Funny regarding the swapping of booze...My friend does this for some of his party's in the late hours...after 1am no one knows what they're drinking...
Nice...
On my 8 cylinder, I pull the port plugs one weekend, starboard the next. Getting 4 cylinder economy now, saving a ton on fuel....
Seriously though...when fishing, I try to make longer drifts instead of the run and gun technique. Saves some fuel...
Spend way more time on your boat, even if you don't leave the dock. The cost doesn't go down but the hours spent enjoying the expense goes up, so the cost per hours enjoyd come way down. And you don't have to mow the lawn, which makes funds available for boat fuel.
You save fuel by drafting bigger boats, like drafting semi's on the highway. :) :) :)
Or just travel at OPS (old people's speed)
Some people I know shut down an engine when boating through a no wake zone to save fuel. And others I know carry their gas in cans from shore to save money. Some run with no water and minimal fuel in reserves to make their vessel lighter and get better fuel economy. And even some never leave the slip, although that couldn't work for me.
