Motor question
deadhead62
I have twin 350 crusaders 1979, can someone tell me what my normal cruising rpm's should be? Next question when I take the port engine over 2200 RPM's it throws the belts off the two water pumps, what is causing this?
#1 Hard to tell because you didn't tell us what kind of boat but 2800 to 3200 would be average. #2 missalignment.
I have a 1978 30 foot Tolly with twin Mercruiser 350s. I cruise about 1500 rpms at about 8knots. 2000rpms will take me to about 11knots. I can run it full throttle and the rpms are about 3000rpm and 4000 when the hull has just been cleaned. Belts slipping off can be caused by being too loose and bent or loose pulleys or even a bad bearing. I would think the most common cause is loose and worn belt. It is not normal for them to come off. Check all bearings and pulleys for tightness and if you can, eyeball the belt to make sure it is on straight.
