- Jan 1, 2000
- 2570
- 203
Just picked up a used 21' center console with a thru-hull transducer and high speed faring block. Unfortunately, its mounted just off center in front of the prop and causing cavitation and needs to be moved. Any thoughts on blocking off the holes left behind? I considered putting in a thru-hull for a new raw water wash down, but the hole is too damn big. Any kits out there that are intended for this? Any ideas are appreciated! Thanks in advance.
