I have a 1985 26' SeaRay with 2010 5.7L 350 Vortec and an Alpha 1 drive. Everything had run flawlessly since this engine was installed at the beginning of the 2010 season. Until yesterday. Two problems that may or may not be related.
Yesterday: Engine started fine but when I put it in forward to leave the slip, the engine stalled. Restarted fine, put it in forward, and stalled again. Reverse was no problem, but forward made it stall. After about the 5th try it seemed fine.
After that, it ran fine idling out of the cove but when I went to bring it up on a plane it reached 2800 RPM and dropped out to 0 RPM like someone had turned the ignition off. Then it dieseled a bit and started to take off again. I brought the throttle back and it ran fine at lower RPMs but every time it hit 2800 the problem would repeat. A friend at the marina told me that he had a similar problem that turned out to be water in the gas. Didn't make sense to me but I put some Startron in and went back out. After a couple of hesitations it seemed like the whole problem disappeared. Never stalled once. I thought it was resolved, but it may have been a coincidence.
Today: When I put it in forward to leave the slip today, I had the same stalling in forward issue. Reverse, no problem but in forward it stalled. After 5 - 6 tries, the problem disappeared. Ran smooth leaving the cove so I started to bring it up on a plane. This time, at 2200 RPM it dropped out. Same symptoms. Shuts right down then diesels for a few seconds as I bring the throttle back and then begins to idle smoothly like nothing was wrong. After the first two times at 2200 it also began to do it at lower RPMS - as low as 1100. If I raise the RPM up in neutral there doesn't appear to be a problem. I brought it to 3000 in neutral and it still was running smooth. I added more Startron just to see, but it didn't make any difference this time.
I'm lost. All feedback would be appreciated.
Thanks in advance.
Thanks in advance.
