Can someone explain what "External Steering - Single Hydraulic" means on the NADA boat value options page? Is this the standard steering that you would find on a mid-size vessel or is this something different?
Got an answer from another source. Thought I would post it here in case anyone else wonders.
"The **** Standard Single Ram Power Steering System is intended for Bravo powered recreational performance sport boats capable of speeds in the 60 to 70 mph range and used primarily in moderate water conditions. The system consists of through-transom hydraulic port bracketry with all necessary hose, fittings, fasteners, aluminum drive end caps and stainless braided line. Once installed, boat drivers will experience significantly more precise steering control, especially at higher speeds"
