sunrunner3300
- Aug 8, 2016
- 33934
- 5
Looking for any assistance is sorting out how to get a Navman / Northstar 6600 unit working properly with the Navman / Northstar dual engine smartcraft (yes, old tech but so are my 2002 Mag 350 merc twin engines)
I have set up the single resistor engine cables to a 4 way junction box and the 6605 unit and I get readings on the display, but only as a single engine. The readings bounce around a bit which seems to be the unit fighting itself for readings.
I'm told on a twin engine set up each display should split to show each engine data (eg rpm shows port engine on the left and starboard engine on the right using the same display) on
I am also unable to change the 6600 unit engine set up for 1 to 2 engines when it is running (and if I force it when I start the engines it default back to 1 engine) .
If I disconnect one of the smartcraft engine harnesses the 6600 unit reads that engine correctly and vice versa.
Specs sheets say that Merc sets all engines to be a "starboard" at the factory and that I need to reprogram the ECM on the port engine to a "port" engine.
There is also some chat on forums that the pin 3 power in the canbus harness needs to be disabled for the port engine to remove two power sources, but its not clear to me how or if that helps or not.
Anyone done this before and know what I need to get changed ?
I am also told the Simrad units will also run the dual engine gateways so I guess the issue still exists.
regards
regards
