Need help from Experts
treeaxx
I am cruising along in my 2001 rinker 270 with a 350 Mercruiser Bravo 3. When I am coming off plane and onto plane the odd time I get a siren or beep at the driver station, like an alarm that something is wrong. From my understanding that should only happen for oil pressure, Water Temp. or Gear Lube. All gauges seem fine (checked gear lube and it was full). What could be causing the alarm. The only thing I found was the oil was a little high could this be causing a high oil pressure alarm?? Not sure what else to look for, the alarm doesn't stay on it comes on and off. Please help!!
Treeax
treeaxx**hotmail.com
