I HAVE A NEW TO ME 87 MONTEGO 2757 AND WAS NEED PLUMBING DIAGRAM IF POSSIBLE. i CONTACTED CARVER TO ASK BUT NEVER RECIEVED A REPLY ANY ONE HAVE ANY IDEAS?
Hmmm, that might be difficult. I don't think Carver published one as part of the owner's manual. I know there isn't any such thing for my 1980 Mariner...
Perhaps someone else here has some ideas - can you elaborate as to your specific problem you are trying to address???
THE PREVIOUS OWNER HAD THE BOAT ON YELLOWSTONE LAKE,
HE MODIFIED THE PLUMBING AND ADDED GREY WATER TANKS FOR THE SHOWER AND SINKS TO DRAIN INTO , HE THEN INSTALLED PLUMBING AND A PUMP TO PUMP FROM THE GREY WATER TANK TO THE MAIN HOLDING TANK. IN DOING SO HE COVERED THE FRESH WATER LINE AND THE INLINE FILTER.
RIGHT NOW I HAVE NO WATER BECASUE THE INLINE SCREEN FILTER IS PLUGGED AN I CAN'T GET TO IT. THIS WINTER I WANT TO REROUTE THE FRESH WATER LINE TO ALLOW ACCESS TO THIS FILTER. I AM NOT SURE WHERE THE LINES RUN FROM THE WATER TANK AND THRU THE BOAT.
IF I CAN ACCESS THE WATER LINE ELSWERE AND BYPASS THE CURRENT FILTER(INSTALL A MORE ACCESSABLE ONE) I WOULD PREFER TO DO THAT
SORRY ABOUT THE CAPS THIS COMPUTER DEFAULTS THERE.
You may get temporary relief by using a garden hose to blow backwards into the filter screen. No factory diagram is going to help with this problem though.
I know the diagram won't help with plug was just trying to get routing so i can figure a plan of attack for re routing around the additional tanks that were installed. sorry no AC unit
Here is mine: tank, filter screen, pump, accumulator, then split to hot water tank and hot water lines, other split to all cold lines. Thats it there is no info on location it is just a schematic diagram.
