When I replaced my old blue carbed 5.7L /270 hp I/Bs spec'd at 4200-4400 RPM at WOT with new 2003 blue 5.7L MPI (Vortec) engines rated at 330 hp each at 5000 rpm, contrary what one might expect with that added 60 hp /engine I was surprised I ended up having to DROP PITCH 2" on the same NIBRAL prop set in order to attain the higher new WOT RPM spec. Most of the increased HP is in the added part of the RPM range.
That worked out well for higher top (test) boat speed , higher cruise boat speed and a little better economy at all cruising RPM. It also gets the heavy 27' boat w/ tower & loads of gear on plane in about 3 seconds at about 1/2 throttle , holds plane at lower speed , and maintains speed and rpm a bit better when fighting higher seas.
Note also, Crusader required larger diameter exhaust hose, mufflers and transom exhaust outlets to prevent undue back pressure issues and allow for greater total exhaust flow at the higher available rpm. ( Old was 3 1/2", new 4 " dia., I believe . )
Some or all of this may apply in your case as well.
As was noted by others, if you are still using the same unchanged prop and gear ratio , no amount of available add'l hp will produce any gain at all in boat speed at any specific rpm which was previously attainable.
