Nextrail Trailers
Has anyone ever purchased/used a Nextrail boat trailer? We are needing to purchase a tri-axle trailer for our 1988 Carver Santego 2767. Our local Carver dealer uses this company out of Florida. Any opinions?
Tami
Yes I have, it is just like every other basic trailer. Mine had problems with the spring set up, broke a couple of springs because they had screwed up on the spacing for the attachment points. What ever trailer you get make sure to spec stainless steel hardware if you boat in salt water and get ss disk brakes.
Cor
My fishing buddy has one, it is nearly 4 years old, a tandem aluminum bunk trailer. It has been no more trouble than usual for a SW trailer. Brakes were replaced after two years, probably will need it again this year. The brakes are drum brakes BTW, don't know if the disc option would have held up better. The price on it was very good, it was delivered from Fla. to Va.
When you call them TELL them what you want! My buddy ordered a trailer from them and told them what boat he had and he wanted it OVER rated(one size bigger) they sent the minimum rating. He sent it back.(exp. he wanted 12.5k they sent 10.9K)they did make it right and other that some surge brake issues and main. it has done fine.
