I have an exasperating problem with my 1989 7.4L Bravo I that will start easily when out of the water on the muffs, but starts very hard or not at all when in the water, particularly when warm. It seems as though the cranking speed has slowed down to about 100-125 RPM over the years but I can find no spec on minimum cranking speed. The engine runs very well after it's started. The batteries are fully charged and the starter is new. Cranking voltage to the starter is in the 10-11 volt range depending on how long I have been cranking. Electrical connections to the starter/ground/bats are all clean. Carburetor is a newly rebuilt Q-jet; ignition system is completely new and heads have a new valve job. Exhaust manifolds and elbows are new, shutters are the new butterfly type (port old-style shutter was completely missing the rubber shell when I replaced it – I assumed it came off in pieces and was expelled, but now I'm not sure??).
I can mimic the problem somewhat when on the muffs by intentionally flooding the engine with the accel pump. De-flooding on the muffs works in about 5 seconds using full throttle, but this does not work in water. I noticed this hard start problem developing prior to any work being done; although, it's much worse now. For a bit of possibly relevant history, prior to any of the above work being done I cooked all of the port side exhaust rubber when my port side elbow water passages became clogged.
Has any body ever had or heard of a problem like this?
