no steering
B CHRUN
17 foot arrowglass steers one way but not the other
real sloppy,looked at cable looks to be pulled apart from the big threaded thing any help on fix and part
140 io merc
There are basically three types of steering:
a) cable. You rarely see this anymore. Basically metal cable routed from the motor to the helm via pulleys. If you don't see pulleys, you don't have this.
b) Teleflex "push-pull" type. It is almost certain that you have this type.
c) hydraulic.
Assuming push-pull, The best results would be gotten via a replacement. You are going to need a lot more info before anyone can help you. You need to know:
Make and Model of the helm station. The length of the cable. The Make and Model of the engine you are steering.
You will also need a broad vocabulary and leather knuckles. :)
Charlie, you may be right. I read it as "frayed and disassembled".
