2002 4.3 Merc, Alpha 1 Gen 2, RWC
Initial start of the season. In driveway, running engine in muffs. Started engine, had normal water flow out of exhaust after a few seconds. Did watch temperature gauge slowly rise and then drop a bit as thermostat likely opened, as it normally would. Engine ran for a good 15 minutes or so. Then noticed temperature slowly rising, overtemp alarm went off. Temperature then dropped, alarm shut off. After a minute or so, temperature rose again until alarm went off. I then checked and no water was coming out of exhaust near top of drive. Water was just coming out from a round muffs. Shutdown engine.
I'm thinking to start with the impeller. But, I just had the impeller changed at the end of last season. After it was changed, the engine was run while prepping it to winterize. No problems at that time.
Any other thoughts?
Any other thoughts?
