Original Norcold frige works fine on AC or DC but lots of water collecting in tray and dripping on floor. (same on any setting)
There is no way for water to exit frig. to Bilge.
Any reason for water acumulatting.?
Bill, Thanks for responce. Door seal looks like it should be replaced, I will try to find the part. Also will cleanup mating surface. New Replacement unit about $1000.00.
Might pull the frige to check condition of floor under it, been dripping water for long time.
That is the main reason I replaced my older circa 1993 NorCold with the newer DE0061T. That and the new unit was more power efficient. My old unit is still in service at my marina the guy installed new door seals and cleaned the mating surfaces.
