Grand Larsony
- Jul 29, 2005
- 18485
- 155
Thought this may be interesting to some folks. I made this up to help me through a PRE-SURVEY REVEIW. This is not the same as a proper survey, but it can help you get comfortable enough with a boat to move ahead towards purchase.
I was lucky enough to be able to have a brief boat ride early in the process and the boat passed my inspection, using this list, so now I'm comfortable with paying for a survey and moving ahead. You could do most of it if the boat is in the water and cover the rest during a proper survey sea trial.
The two most important things (per my surveyor) are 1) Ability to hit WOT recommendation (easy if you can get a boat ride) and 2) proper check for hull moisture (which not many boaters can do without help).
Feel free to add to, or comment on, the items below:
1 On land: Sea strainers, through-hulls, anodes
2 On land: Outdrives exterior condition, transom assemblies, hydraulics, props, skegs
3 On land: Hull & transom soundings, swim platform, hull-deck joint, gelcoat, bottom paint
4 On land: Full camper canvas, snaps, studs, eisenglass, zippers, stitching in good condition both deployed and stowed. Boots for storage postiion.
5 On land: Seating surfaces, cushions, carpets, vinyl, headliner, wallcoverings in cockpit and cabin
6 On land: Stanchions, anchor locker, bow pulpit, exterior hatches, windshields, ports, side vent windows, bright work, teak, ladders, companionways, storage lockers, etc.
7 On land: Full engine room & locker inspection: engine mounts, wiring, tanks, hoses, bilge areas, water leaks, scuppers & drainage, etc.
8 Negotiable: Compression test & leak-down testing both engines
9 Sea trial: Battery fluid and voltage levels, mounting & wiring, proper operation of alternator and charger on shore power
10 Sea trial: Gas, waste, & water tanks - mounts, fills, vents, pump out fittings, hoses, clamps
11 Sea trial: Galley microwave (shore power), fridge (dual voltage), sink, and stove (shore power) operation, galley cabinets & surfaces, doors & drawer operation
12 Sea trial: Stereo operation
13 Sea trial: Air conditioning & heat operation, water flow, cold air, noise level, odors
14 Sea trial: Head toilet, sink, shower operation & drainage
15 Sea trial: All cabin panel switches, fuses & wiring, etc. Pull panel to inspect.
16 Sea trial: All 12v cabin, cockpit, navigatoin hull lights, switches, and AC plugs (on shore power). Verify GFCI operation.
17 Sea trial: Electronics operation (depth, radar, compass, spotlight, synch, sniffer, VHF, etc)
18 Sea trial: Blowers (2) & bilge pumps (2)
19 Sea trial: Start up both motors (cold and hot), check gauge operation and readings, check for leaks & noises
20 Sea trial: Acceleration and performance. Check planing speed withwithout trim tabs and drive trim.
21 Sea trial: I/O operation, trim & trailer switch operation
22 Sea trial: Steering & throttle operation
23 Sea trial: Top speed & max RPM
24 Sea trial: Hull stability, turning radius, skatingplaningplowingbackdown issues?
25 Sea trial: Trim tab operation, fluid level, hoses & fittings
