Hi Guys,
We are getting closer to pulling the trigger on a new to us (2007) boat. As part of the survey an oil analysis will be done. I am pretty sure the current owner changed the oil prior to winter lay up. Would whether an oil change was completed or not have an effect on the results of the analysis? I would imagine that if the fluids were changed, we would run the engines for awhile prior to taking a sample but I'm not sure. If I am incorrect and the oil was not changed prior to lay up what effect would this have on results?
Thanks for your input.
max
max
