Hi,
I have a 97' Searay with a 4.3L LXGen+
I had my mechanic do some maintenance on the boat and after all this was done, he started the boat and it would run a few seconds and stall. (Prior to his visit I had the boat running and it didn't stall at all). Part of the work he had done was replace the oil sensor since it was not reading anything on the guage.
His diagnosis was the carb had to be rebuilt. I asked him if there was anything he moight have overlooked since it didn't stall before he worked on it. His answer of cause = No.
So.... I agreed to have the carb rebuilt and went the extra yard to have the fuel polised (there were minor particles in the fuel so I decided to pay the $200 to have the fuel polished and not risk the $500 I spent to rebuld the carb).
Rebuilt carb was installed (I was not home when he came to do this)
NOW... when I turn the ignition on the fuel pump keeps priming (before he touched the boat, I recall it would humm for a few seconds and stop)..
I called mechanic and answer I got was ..."Huh..don't know maybe the fuel pump got dirt from the bad fuel, if the boat is running use it."
Looking around I now see the wires to the oil pressure safety switch is bypassed (purple/yellow & purple cable tied together) - prior to his repair they were not.
Why would he tie these wires together and not put them back on the sensor where they use to go???
What I'm thinking is he rebuilt the carb (at least I hope he did) replaced it (when I was not home) and found the issue with the stalling was solved. He then realized he mis-diagnosed the issue and may have damaged the pressure switch/cable when replacing the oil sensor and masked it by tying the wires together. I guess it was Sunday and he couldn't get one.
From my research it seems bypassing this oil pressure safety switch is not a good thing as the fuel pump is continously on... correct?
I am thinking to remove the bypass and place the wires back on the switch to see if the engine stalls and confront him. Does it matter which side of the switch the wires (purple/yellow , purple) go?
CHris
CHris
