Anyone use the subject system? The manual doesn't say much other than turn it on. Does the oil discharge out of the clear plastic tube? Is that tube also used for putting in new oil?
Do you just lower the tube as much as possible to get out any residual oil or is there a good way to get it clean?
I would imagine it just pumps until nothing comes out then shut it off? Do you typically stop the pump then wait a bit to get any newly drained oil?
Sorry, I know it sounds simple, but wanted to check with someone who's used one.
Thanks!
Thanks!
