I recently installed a Sierra electronic conversion kit into my Mallory dostributor on my 260HP OMC. I also installed the Rapair CDI shift interruptor unit compatible with the electronic conversion kit. I timed the engine and set the idle on muffs in the driveway and everything seems to be working OK but I find that if I don't shift very briskly into foreward, the engine will occasionally stall.
I have idle set to 550 rpm in gear and the timing is set to 10BTDC. I have no trouble with the stalling going into reverse gear. The info with the unit instructs to be sure the coil resistance is 1.5 ohms, which mine is, and also to be sure the external ballast is 1.5 ohms. On my engine, that is a violet/red wire on the positive coil. My shop manual says to check the resistance between the coil end and the 20 ga. purple wire on the alternator. Trouble is, I have a two wire alternator and no purple wire, one is yellow about 14 ga.and the other is brown about 6 ga.
Does anybody have any ideas?
Anyone have a similar experience with stalling?
Maybe this is normal and I just need to adapt to a quicker shift stroke?
