Open Array on 42" pole Mount
I am nervous about this lowrance unit I bought from boatfix. It is a 5' open array, weighs 46lbs and will be mounted on a 42" pole mast forward lean that comes off my radar arch.
Regal mounts the radaome on the mast which weighs about 25-30 lbs depending if you get the 2kw or 4kw.
Am I asking for trouble with this setup?
Do I have to mount it on the pole mount?
The reason for the pole mount is to get it above the bimini top since the arch sits low.
Any advice appreciated!
CurrentSea, go to ScanStrut (dot) com. They make many Aluminum or Kevlar POWER TOWER Mounts that will easily hold the Open Array & much more. These are high quality mounts. I've used them in the past & was always well satisfied.
It's going to look a bit like a helicopter blade on a boat your size up that high IMHO.
Do you use radar enough that you really need a 5' open array?
As long as the pole is at least 3" diameter SS. I'd go 4"
If you can get away without using a 42" pole I think it would look a lot better. As far as the pole being strong enough you need to consider the arch that it is being mounted to. At cruising speed you are talk about a lot leverage working against it. Make curtain it will hold up if for no other reason safety. I would hate for someone to get hurt because you couldn't pass up a good deal. And yes it was a great deal I came close to buying it myself. Let us know how it works out.
Hey's somewhat stuck with the pole. The "radar arch" on this boat is more of a safety rail on theaft side of the sundeck. Radar needs to be mounted another 4ft higher to clear the canvas of the bimini and get the helmsman out of the beam. Looks like the radome is the right choice.. IMHO.. 5' open array is a lot for that boat...
My concern would be "wobbling" of the array base, especially at speed, and in heavy winds. You want the base to be solid enough that the rotation of the array does not cause any wobble.
You might consider making a tripod with the 42" pole as one leg. The tripod radar mount is common on commercial and millitary vessels.
Dave,
I would certainly be concerned with the stability of that much weight up so high. I have the Radome and can see it moving while underway. I have never seen that boat with an open array but my thought is it may be overpowering.
The only difference in radar arches is that I beleive yours is fiberglass while mine is aluminum.
Just for prospective This is a 2004 with a SS tube Radar Arch
The listing said this is a 4ft open array and a bigger unit could look like it’s on the verge of becoming a gyrocopter [:-propeller]
I'll throw in my 2 cents as well since I have the same boat. Seems like a lot of rotating mass for the existing mast/arch combination. Mounting it on a lower mast is out of the question unless you want fried brains!
I think I agree with everyone.
Real bonehead move on my part, but I still like the lowrance unit for a gps.
I am gonna go back to using a Radome and forget the open array.
If anyone is interested, I will sell just the open array or the whole setup.
Email me with any offers.
I guess it looked like such a great deal and really did want a open array.
If I ever get a hardtop, this would be a nice setup!
Dave, you could always mount it on the TV you have listed in the classifieds.
You could also mount it right above your windshield On the Fiberglass Band and let it project out to clear on a platform. Scanstrut makes that type of mount too. I'm looking at the photo that Andy (Abalmuth) posed of the Cruisers Yachts
Why don't you see if you can make a trade for a smaller open array radar?
You got a good deal on the bigger one, maybe someone will be willing to make a trade.
"Mounting it on a lower mast is out of the question unless you want fried brains!"
Old wives tale. It's really not a problem on small radars.
I have seen a lot of them mounted on top of the cabin, in front of the flybridge.
A 5' open array would cover the whole bow. Never mind scramble a few brain cells.
I was talking about the fried brains thingy.
Did some one say Fried Beans!!! I like mine with a hot dog and cold beer.
I would agree with all as well. A 5'open array on a 42" pole would get me nervous.
I would consider buying the whole set up. I have not yet subscribed to boatered. email me at seadation87rb2@gr5toptonline.net
