Trying to run a 1998 5.7 engine with thunderbolt V ignition on a stand.
There are three sets of electrical connections not hooked up:
The connectors that attach to the stern drive oil reservoir
The connectors for the shift interrupt
Finally some connectors toward the back of the engine that I believe are supposed to go to drive trim senders
Do I need to connect these circuits to themselves to run the engine...or does leaving them not connected replicate a “thumbs up" from their respective switch?
Finally, I've hooked my positive battery directly to the main level g on the starter. I have a momentary switch to activate the starter.
I have a toggle switch hooked up to the battery to power the + on the coil. Do I leave the purple wire on the + side or do I take it off since I'm powering that side with a dedicated wiring off the toggle switch?
