Chris:
You're going down the RIGHT path!! Follow the Force!!
Sounds like the Broker is a step ahead and wants to make this deal work. They are busting their hiney's to get stuff up to snuff. I'm not even sure my trim gauges work? I'll have to go look and it's an excuse to go mess around on the boat. I've been doing it all day anyway! Got her tuned up and had the starboard shift cable replaced today in my driveway. That was fun! I should have done the tune up part myself. There is nothing to do! We pulled the ORIGINAL plugs out from 1989! They were pretty hammered, but still working. I'm sure a new set will make a huge difference! Did the cap and rotor and wires too. Topped everything off and she fired right up. I love the sound of a 454 running in the driveway, but the 350's are pretty cool sounding too!
The Sync gauge hooks to a tach wire from each engine. It sounds like one has come off somewhere. I'd switch the wires and see if the sync gauge moves the needle to the opposite side. If that's the case, then it's probably just a dead wire. I think they are purple, but I'd have to crawl up under the dash and find out. There should be one for each side, obviously and another wire for power, I think. I'm sure you are familiar with them, it just leans to the engine that has fewer rpm's. The best way to describe what it does is the sound that is made when they are out of sync. It's kind of a wow, wow, wow, wow, noise. As you adjust the rpm's it become a longer slower wooooooooooooow, woooooooooow, wooooooooooooooooooooooooow, noise. Eventually, it kind of goes away. I don't know how else to describe it with words!!
A lot of people connect their toilet to the freshwater system. Then they get sick and figure it's because of bad water. Yes, it's bad water because stuff is moving from the toilet upstream! UGH!!
I was in NYC last week and I'm flying in again tomorrow! I wish I could bring my boat with me so we could compare notes and go for a ride! Ours planes very fast compared to our 250 DA with the 454 in it. It's so much smoother and only has the bow up if you don't give her enough juice with the tabs retracted, just the way your described the broker driving it. Tabs down and she stays pretty flat.
