outboards
Aaron C
I have a 89 bayliner 2755 does anyone know how I would go about mounting a outboard bracket on the swim step and what size kicker would push it.
Here's one for a 9.9HP motor: http://www.adventuremarine.net/motor-brackets.cfm#10000
A 9.9HP will push your boat, but how fast is the question. How much does your boat weigh?
9.9 should do the job nicely. If it's a bolted-on platform that's probably all it can safely handle.
5 knots is about all you can expect; much over that and the power required goes WAY up.
i had a 15hp kicker on my old 85 2550, pushed it fine... make sure you get a long shaft outboard for the prop to be well below water...
bracket was similar to those above.
