Outdrive Damage?
surfdwn
I was getting ready to take my trusty 1976 SeaRay 190 on a dive trip recently and was checking the boat out. It did not want to go into reverse. It would reverse at idle, but as soon as any throttle was applied, it would die. Forward seemed fine.
I decided to check the gear oil. The outdrive was rebuilt last Summer (by a local marina), so I was not expecting any difficulties. Wht I found shocked me. The drain plug was missing! More than likely it was missing since last Fall. I took the boat on a dive trip (saltwater) in May and noticed the reverse issue when returning to dock.
I tried to fill the lower unit, but oil came out between the lower unit and the upper unit, so i quit. I assume a seal or gasket is leaking badly there.
My question is....how much and what sort of damage can I expect from running this outdrive last May? With the drain plug missing and the gasket/seal problem, I assume that sea water has been in the unit. It was run for about a hour that trip (over two days).
David Nolen
My honest opinion is that the entire insides of your OD is toast. Needs total rebuild.
The plug was probably there, but just worked loose at some point. I'd go back to that shop and work with them to come up with a cost effective solution to the problem. As in, give you a break on the repair. It's probably more their fault than yours but you DID notice something wrong back in May, right? That would've been a tip to check fluid levels. It's too late now so I'd work on a way to at least keep the costs down on getting it fixed again.
Originally posted by surfdwn
The outdrive is a Mercruiser 233HP
The engine is a 233 hp. The drive is most likely an Alpha. Your Alpha needs a major overhaul or replacement. Do not operate the boat until fixed/replaced.
