I have Volvo 5.7 GI/DF motors in my boat. Yesterday while underway cruising at 4000 rpm the High temp alarm went off and the motor went into limp mode. The gage was at 200 degrees. I shut it down and limped home on one motor. Pulled the impeller which looked fine and replaced it with a new one. Temp seems to be OK at the dock. I will test ride later this week. My question is, what damage could I have done to the motor due to the high temp and what else should I be checking. It took a while to get the motor started after replacing the impeller. Thanks for the help.
