- Nov 4, 2006
- 24150
- 1,309
I have a 1985 Carver 3227 with Crusader 270 hp motors and v-drives. I had the couplings repacked in the spring by my mechanic. Normal drip before but I've had the boat for five years and have never had it done so I thought it was time. When they put the boat in the water there was no drip at all. Possibly too tight? The first time out I was up on plane and smelled something burning and looked in the engine compartment and saw the couplings streaming water. Called mechanic and he came over and tightened them.
Was Ok for a while but to had to tighten again after about three hours of run time. I was at the boat today and water on starboard side is a drip per second and the port side is a steady stream. The water slows after it sits for a while but the bilge pump kicks on occasionally.
Now my question. I believe that the packing nuts were too tight at the beginning and the friction burned the packing, causing issue that I have now. Does this sound reasonable and is it fair for me ask my mechanic to pull the boat and redo the packing at his expense?
