pc to garmin plotter
Well-known member
is there any way to planr routes on a pc then transfer to a garmin chartplotter
Yes. Some Garmin receivers come with a software package called MapSource which allows you to do exactly what you describe. If it was not included with your chartplotter I believe you can buy it directly from Garmin.
Even though I use a PC as my main GPS/charter with Garmin BlueCharts/Mapsource/nRoute I download all my ‘stuff’ Routes, waypoints, breadcrumbs ets via a card reader and install all to an older Garmin unit I have on the bridge- I think the newer units use SD cards
What’s neat is that you can share files with other users. When we decided to go to Redbank for the first time a couple of years ago, Dan(Boatbum) sent me his Breadcrumbs from his trip there, he draws more than me so if his course was deep enough for him without issue it would be fine for me
Some of the older models you could connect a laptop directly to the unit to transfer data (again using Mapsource software). My new unit you can only transfer data using the SD card I'm not sure why they removed the serial interface. There still great units that a simple to use.
Mainly because newer comouters don't have serial ports on them anymore. Now there is no reason that Garmin couldn't put a usb port on their equipment, I wish they would. I have to use my daughters' computer to update my handheld since my computer has no serial or parallel ports, and doesn't like the usb convertors.
An inexpensive Serial to USB Converter Cable will enable a GPS with a serial connector to connect to a computer. You can find them for 10 to 15 dollars on the web. Mine works great.
I have a copy of mapsource but it has no detail of the water areas, only highways. My Garmin 5212 has all the charts preloaded so I dont have a disk. What I want to do is plan the routs at home than load them into the garmin. I thought that was what the smart chip and mapsource was used for.
are there any garmin users forums? The Garmin "blog" is all puff pieces from Garmin.
I use a SD card on my Garmin 192C. The SD card plugs into a SD card reader (via USB). I do as others have mentioned....back up my tracks, plan routes and share data with others that have a Garmin and are using Mapsource software.
Russ: If I understand correctly you are recording the tracks from your plotter to your PC for back up. What I want to do is plot the course on a chart on the pc and then load it into the garmin.
Hi Bruce,
Yes I can backup my data from the GPS onto my laptop. But I can also plot a course on the laptop (like you are talking), save that file to the SD card and then plug the SD card into the GPS and add the data - just make sure you don't have the OVER-WRITE (I think that's what it was called) box selected. You want to add data to the GPS not overwrite what's already on there.
Do you have charts on your mapsource? If so where did you get them??
http://www.boatfix.com/shop/scripts/prodList.asp?strSearch=010-10320-00
Thanks Andy, I see that is the mapsource SW and one chart area. I already have all the US charts installed on my 5212 does your link mean I have to buy the entire set of charts that I already have to duplicate my plotter coverage???????
Since your 5112 came unlocked for all charts i would contact Garmin support and tell them what your trying to do and see what they say
Bruce - basically, yes.
Mapsource by itself doesn't contain any detailed maps. So, you have to buy a Bluechart CD and pay to unlock your region.
Even worse, you can't buy a 5012 w/o the pre-loaded charts and use the Bluechart CD to add in your region. The 4000 and 5000 series use only the G2 charts which come only on an SD card - not on a CD.
So yes if you want to do trip planning on a PC you must buy a solution that only works on the PC, not the plotter. We've had this discussion a number of times on THT, and the answer is always the same. With the otherwise excellent customer focus at Garmin, I can't figure out why they don't have a better solution.
I'd like to do planning on my PC but don't feel I would use it enough to justify the extra $$.
Not really. The package I bought included MapSource, all the charts (locked) a chip burner, a blank chip, and one unlock code to unlock one region.
You don't need the chip burner for the new models, they use a common SD card.
So - You get Map Source and the CD with the charts on it, and use the unlock code to unlock the region you boat in. Need more regions? Buy one or more additional unlock codes. You don't have to buy the codes directly from Garmin, many vendors sell them, some at a discount. The last one I bought was from amazon.com.
This works better for some of us than for others. I live in Charleston, SC near the Garmin regional border so I need one to go south and the other to go north.
So, to answer the OP's question, buy and install the software on the PC, register the software to your plotter, plot your routes, uploar them to a blank SD card, remove the card and put it in the plotter, and download them.
Ron, what hardware did you do this with? The older versions used the proprietary Garmin card, and the Bluecharts on CD were compatible with those Garmin GPS units.
The newest GPS units use ONLY the G2 charts, and they are available ONLY by preloaded SD card. So, it is possible to get Garmin charts to do trip planning on a PC. But they cannot be reused on a late-model Garmin GPS.
My 5212 does not have a serial port only the SD card slot.
Bruce,
This stuff gets somewhat complicated with all of Garmin's rules about licensing and whatnot. Depending on what your purchased chart-wise, you should be able to unlock them on 2 chartplotters as well as MapSource. Give Garmin a call. They have very good marine support (early mornings is best for getting through quickly).
