Originally posted by chriscraft67
Bill,
I assume your heat exchangers have coolant recovery bottles attached to the overflows on the head exchanger fills. If they do, there is a difference in the design of the caps and you need to specify coolant recovery when you buy them. It's not a problem, they are very common.
By the way, the two MOT GMRS radios you sent to us a couple of years ago are working fine and are used for bridge-to-cabin comms on every cruise. It's the only radio that the Admiral is truly comfortable with.
Good luck with your GulfStar. I have always admired them. I make sure I read all of your posts.
KB1ULU
