I replaced my older plastic transducer this past weekend with a new brass B60 for my new GPS/Sonar. I wanted to use the same hole as the existing factory installed unit so I didn't have to expose the core material anywhere and minimize underwater holes.
However I was quite suprised when I removed the old one. It was plastic with a screw on top to a tube that goes through the hull. The actual transducer piece slid into the tube and was held in place by the screw top. If the plastic screw top cracked it could easily sink a boat. If anyone has one of these, you might want to check it out.
BTW - Boatfix got my transducer delivered on time for the weekend install, Thank you guys!
MJK
MJK
