Problem: Turn Key,Electric fuel pump runs, Engine does not turn over.[
All fuses and wiring looked OK. Nutural safty switch in nutural[:-banghead], found wire to switch looked OK,but on farther inspection,found wire corroded inside insulator and seperated.
Solution: Replace conectors at switch, turn key,WROOOOM
Good feeling when problem solved.
Happy ST. PATRICKs DAY to all!!
