Originally posted by Radioactive
This is a frequent question. ( I'm biased, and would not have a non-marine genny aboard, but I will attempt to give a straight answer... )
Those who wish to use a small non-marine generator aboard seem to be in near unanimous agreement that the Honda is the most desirable. The Yammy has also been mentioned.
Most 2kw generators would find a 10k BTU A/C to be a challenge, at best, and won't work in some cases.
The consensus is that it should be placed on the swim platform, astern. Place it on something to raise it up a bit, to help avoid splashing.
In all cases a CO monitor should be used. Maybe two (2). Gas generators can ( and do ) kill. Be careful.
If I were to do such a thing ( I won't ) then the best choice seems to be to use the Honda 2000I and a smaller A/C such as 5k to 7k BTU.
Whatever you do, please be sure to keep safety at the very top of your list.
I hope that helps.
