Don't make it too long, or you'll find it too cumbersome to follow. Mine's mental. I do everything in the same order so I get into good habits.
1. Before leaving the driveway, hook up muffs, turn on water, check for flow, start up engine and run it for 5-10 minutes. Shut it down.
2. Tilt up motor, check stern straps, insert plug, check bow strap and cable, check tires, check cover snaps.
3. Hook up to tow vehicle, check lights.
4. Check breaks in driveway before pulling out on road.
5. At ramp area, pull over and disconnect lights and stern straps, remove cover.
6. Check plug.
7. Turn on blower.
8. Back down the ramp, tilt motor down, start engine.
9. Remove bow strap and safety cable.
10. Back off trailer and dock boat at courtesy dock.
11. Have FUN.
