- Jan 24, 2008
- 29275
- 25
I have a 92 Wellcraft with a 7.4 engine. I changed the oil this weekend (Friday)using the preluber. Everything worked perfectly until Sunday morning. When I turned the key, the preluber did not come on like it always did before. It was working immediatley after the oil change. I visually checked the fuse and it appears to be ok. It seems to coincidental that it stops working after the oil change but I can't imagine what went wrong. Basically all I did was disconnect the hose from the engine using the quick disconnect, aim it to a 5 gallon bucket, turned on ignition and out came the old oil. Connected back hose, put in new oil and checked. Everything was fine. Like I said, it was working immediately after the oil change. I will check the fuse with a meter but I don't think that's the problem.
Ed
Ed
