Preventing Rust on new Engines.
jmas
What would be best coating to apply to new inboards to help prevent rust. Boat is in salt water all year.
Any suggestions wold be appreaciated.
Boeshield.
But no matter what you put on, if it's on areas of the motor that get very hot it's more than likely going to melt away. The best thing you can do is keep the engines clean, dry and stay on top of any leaks that may develop. Also prime and paint any spots that develop corrosion as soon as you see them.
What Bill said and I cant stress important it is to identify and fix any leaks ASAP. Corrosion pro works as well. Those hard to reach places need extra attention and a fresh water wash-down occasionally with good dry our helps too is you have good opening hatches.
Joe,
I installed block heaters to keep the oil warm. That intern keeps the entire motor warm. Morning dew does not form on the motors . Makes a huge difference. Boats 10 years old and motors look fantastic .
Originally posted by Robski97
Joe,
Rob, Thanks for suggestion. What do the heaters look like,are they 110 volt,how do they attach to engines?
Is the motor in or out of the boat?
I got hard two part epoxy bottom paint with teflon. I guess Interlux was discontinuing it so it was cheap. I got 6 gallons of the stuff and use it on everything besides the bottom. Stuff is tuff, a little bit non stick and brilliant white. Painted my bilge and engine(and exhaust) and outdrive. Only the area around the exhaust ports on the heads turned a little yellowish brown. been over 5 years.
Wolverine pad heaters have worked great for us over many boats and many years now.
We use the 250 Watt heaters mounted on the oil pans and they work great - here is a picture of one of them installed just to the left of the engine mount and just below the left side oil filter - it is orange in color.
Hope this helps
A good coating of CRC at layup and bilge heaters work well for me.
Don't use CRC if your motors are painted white, I did this year and now I have tan spots :(
Originally posted by jtybt15
Is the motor in or out of the boat?.
New engine going into Boat next week. All parts have been painted with Rustolium Ceramic Paint. Anti Corosion spray and good ventilation sounds like the way to go.
No need to heat engine oil here in FL. Engines start up fine, RUST has been my problem.
Thanks for all sugestions.
Keeping an engine warm while at rest is about more than ease of start ups. It can keep out moisture that can get into any cylinders that have there exhaust valves open while at rest via the exhaust system.
Ceramic paint, huh! Sounds kinds gimicky to me. In order to get ceracics to fuse, it has to get to a temp approx 1600*. Probably the best paint job would be power coating. My understanding is powered paint pigment is sprayed on positively charged surface. Then it's baked...at a much lower temp, to melt the paint onto the surface...Pretty much like they used to do on industrial baked enamel.
Which CRC did you use? There are many different types. I used the CRC656 and I will check my motors but I didn't recall seeing brown spots and my motors are white.
I am sure the brown will burn off as soon as it get's hot.
Boats with the engines under cockpit hatchers are the worst. Keeping a good seal on the hatches is easier said than done.. Check the seals and drains but IMO they require extra attention to rinsing and drying that engines in nice dry below cabin ERs don't.
With the high humidity in Fl. Block heaters would keep the motors moisture free....
