I've indicated in a couple of previous posts on the old site about my having missed that there even was a primary fuel filter on the generator.
There wasn't on my 402 and Regal engineers in their infinite wisdom included one on my 4260. Unfortunately my dealer didn't know about it, my Volvo mechanic didn't know about it and I darn sure didn't. So, after fixing the leaking hatch hinges that caused the generators alternator failure and waiting for the new primary's to arrive I finally put one on over the weekend.
Being a fairly bright fellow who didn't really fit anywhere near where the filter is located (port side, aft, fastened to the stern just above the muffler) I carried some diesel fuel, filter wrenches and rags with me into the engine room. The first thing I did was to turn off the fuel going into the engine primary filters.
It took a couple of different filter wrenches but eventually I got it broke loose. Once loose a little fuel spilled. No big deal, that was the reason I had rags. Once the filter was removed the fuel POURED out and there was no room for a bucket to catch it, at least not any bucket I had with me. The filter is a two part assembly and it's necessary to take the plastic water separator off (two filter wrenches to do this), clean the separator, replace it on the new filter and put it back on.
In the meantime, fuel was running in the bilge. LOTS and LOTS of it. There is NO SHUTOFF!!!
There was no need to pre fill the filter as the fuel was RUNNING out of the assembly. I put it back on and the fuel quit. To make sure the filter was full I bled the air out and cleaned up a couple/three/four gallons of fuel from the bilge and that is GREAT FUN.
Starting the generator turned out to be a bit of a hassle. It cranked right up, ran for ten seconds and shut down. It sucked the fuel out of the secondary filter and that was that. I refilled the secondary, started it again and it kept running so now the problem is solved. For the moment.
I need to find a bucket that fits under the primary filter or change it the next time when my fuel tanks are low.
Since it had been three years the separator was dirty and needed cleaned. This is simply another fine example of Regal engineers getting their jollys by screwing over a customer. If I could fit in there I'd put a shut off valve on the line and may have the mechanic do it the next time I have something for him to do.
I will have a post in the next couple of days about the fine job the OEM canvas folks did providing the replacement canvas.
Mike, Palm Coast, FL, 04 4260 with a new generator primary fuel filter
