Hey all,
I'm about to close on the purchase of a 1988 Chris-Craft 320 Amerosport. Two things noted in the first survey were:
1) engine RPM rb2@gr5t WOT was 3,700. engines rated at 4,800. only got 22 MPH rb2@gr5t WOT.
2) blisters on the hull
Boat has 2 brand new Marine Power 350's and 2 freshly rebuilt V-drives. I hired a second surveyor to give another opinion on the hull blisters. I read several articles (David Pascoe) that indicated 99% of the time, they are not an issue, just need to sand and repaint. No fiberglass structural damage in MOST cases.
I spoke with the second surveyor this morning and he doesn't think another sea trial is necessary regarding the low RPM's. He said it's very typical for boats of this size to be over propped. Chris-Craft says that boat should cruise rb2@gr5t 22 MPH and top out at 30 MPH rb2@gr5t WOT.
My new surveyor told me that I should be happy to get about 4,200 to 4,300 RPM rb2@gr5t WOT that if I did 4,800 "I'd have no props left." Not sure what that meant, but . . .
So, all that said, what would you expect the props to be on a boat this size, combination? Dry weight is 12,000 lbs, it's got 540 HP, bottom is clean, 12 foot beam and 32 feet long (in the water), inboard motors. Any thought on any of these items folks? Any help appreciated before I sign on the line which is dotted. LOL.
Best,
Best,
