Originally posted by KiDa
Originally posted by JimPend
What you are decribing sounds more like a shaft puller, the porp pullers I've used are more like big gear pullers. See
http://www.henrysmith.com/toolinginboard.htm
That's what I thought. I googled prop knocker and it is something I have never seen or heard of before.
http://i161.photobucket.com/albums/t213/Herculesrhapsody/DSCF0835.jpg
http://i161.photobucket.com/albums/t213/Herculesrhapsody/DSCF0834.jpg
Here is a post from the folks at the Hatt owners site.
i got a little curious about this problem so i ran a simple analysis to see what force would be transmitted to the transmission end of the shaft when you hit the prop end with a hammer. the analysis was done as a non-linear problem with a time dependent solution. the force from the hammer was delivered to the shaft in the time shown on the time curve graph. the force goes from zero to 800lbf and then returns to zero in 0.05 seconds, the value of 800 lbf is just a guess. the second graph shows the reaction force on the transmission end. it is significantly lower than the input force, and shows more than one peak. the third picture shows the problem setup and resultant stress. it may not be that easy to read at this reduced resolution, but the stress on the shaft is insignificant. the shaft was held in place with two cutlass bearings that allowed the shaft to translate and rotate. the bearings were rubber but with only minimal friction. the shaft was fixed at the transmission end. the shaft was 316ss, 2 inch diameter, 15 feet long, and weighs 162 lbs. the prop was just a round bronze disk at 20 lbs. much too light but an ok starting point. if anyone knows the weight of a representative prop let me know and i will try to dial in the solution a little better.
