Prop question vibration
ctcruiser
Hey guys I have a BIII drive and slight vibration/sound (like a cavitation sound) when I turn my wheel to either side at any speed above ideal speed The noise gets louder but not that loude no one eles really notices unless I point it out the tighter you mak a turn. I have replaced u-joint, gimbal bearing, and had alignment check drive shafte appers fine. So the only thing I have not done is recondition my props. Props look good however their is a very slight nick on 2 of the blades andwhen I say slight I mean slight. The boat is now in the water can I remove my props while the boat is in water to have them reconditioned just removing the boat from water is no cheap. or am I ok leaving them as is and replacing in the fall or at least mid season then I could do the anodes at the same time.
I have also been told by more then few not to be to concerned because they have the same type of vibration/noise on their boats with bravo III drive.
Thanks guys
